PTO pump question
Rick
01-09-2002 11:36:56
I have a 411B and run my front end loader off a pto pump-runs too slow off the engine. All is good EXCEPT when I need to use an implement such as brush hog that requires the PTO. I have to raise up the bucket, unhook the PTO pump, etc.
Is there such a beast out there that is a PTO pump that has a splined shaft out the back end of it, so that I could just attach something like a brush hog up to the pump's splined shaft? This would make my life so much easier.
Thanks in advance.
Rick
Rick
01-11-2002 11:44:40
 Re: Re: PTO pump question in reply to Larry, 01-09-2002 15:13:47
If I'm following the manual correctly, the original setup is there up near the front of the motor - was told the previous owner re-hooked it up this way because orginal hydraulics were way too slow.
Larry
01-11-2002 15:10:45
 Re: Re: Re: PTO pump question in reply to Rick, 01-11-2002 11:44:40
It was probably slow because the hydraulic cylinders didn't match the pump. I think the 411B was a high volume low pressure pump,so you would need larger diameter rams. If it was a high pressure low volume pump you would need smaller ones.
The reason I asked was because I had a 411B with a loader on it,and it didn't work right until I put the right size cylinder on it.
So,what this boils down too is this; get the pump on the tractor hooked up to the loader,and make sure you have the proper size cylinders.Then you won't have to look for another PTO type pump.
