Crankshaft
kenny
01-07-2002 21:43:59
I own a 1944 case SC that was given to me on my 10 b-day. I compelty restored it and Franklin mint recently made a model of it. i let a friend use it for a show and he spun my #1 rod bearing I have an in the block crank grinder but i have already taken it down to 42 under and that is really thin. I can't find a decent machine shop to spray weld it and am looking for a good crank on both rods and mains because they don't make main under sized and don't want to get mine relined. can anyone help??
george md
01-08-2002 00:17:37
 Re: crankshaft in reply to kenny, 01-07-2002 21:43:59
Kenny, where are you ? I do metal spray, but i would
recommend that it be welded (gleason process)rather than sprayed. I also know a good shop to weld and
grind. you said that you are .042 under now, bearings only go to .030 under. send an email if i can help
