I NEED A GOOD USED INDUSTRIAL TYPE TRACTOR FOR UNDER 15000.00
JIM
12-30-2001 00:01:44
I NEED AN ALL AROUND TRACTOR FOR CLEARING AND LEVELING HOME PADS, GENERAL CLEAN UP, LOADER WORK, ETC. WHAT CAN I GET THATS IN GOOD SHAPE, I KNOW THE IMPORTS ARE PRETTY CHEAP BUT I WANT TO STAY WITH AMERICAN.
James
12-30-2001 17:54:05
 Re: I NEED A GOOD USED INDUSTRIAL TYPE TRACTOR FOR UNDER 15000.00 in reply to JIM, 12-30-2001 00:01:44
Sounds like you would mostly be using it for the loader. You can get a lot more done and a lot faster with a bobcat. Attachments are not cheap, but you can buy one to do just about anything a tractor will do.
GEO
12-30-2001 13:48:43
Saw a 580C with box blade for sale in OK. It will not have PTO because it has a shuttle.
gm
12-30-2001 07:38:33
check out my 530 backhoe on ebay, ends
tomorrow.
-Greg
Bill
12-30-2001 18:57:40
 Re: Re: I NEED A GOOD USED INDUSTRIAL TYPE TRACTOR FOR UNDER 15000.00 in reply to gm, 12-30-2001 07:38:33
Greg, It looks just like mine. Mine is a 62. I just finished putting in an inlet and about 80' of drain pipe. The deep end was about 10'-12' deep, and the only prblem I had was keeping the front end down when I hooked into some junk, with the hoe extended. The hydraulics almost seem to strong for the weight of the machine.( I believe its arond 8300 lbs) I would have to be pretty hard pressed to give it up.It's a good machine. Bill
gm
01-01-2002 16:10:52
 Re: Re: Re: I NEED A GOOD USED INDUSTRIAL TYPE TRACTOR FOR UNDER 15000.00 in reply to Bill, 12-30-2001 18:57:40
Sounds like an exciting time. I think
the rip strength is like 23k lbs(from the
book), that is probably why it can move
the machine around without any troubles.
If I end up selling mine, I will probably
buy another one later on. Getting
my credit cards paid off is the goal right
now :)
-Greg
