Timing
480
scooterhead
12-23-2001 05:56:04
My 480 backhoe spun the distribiter around 4-5 times till the wires were twisted all up . This has happened in cold weather before , seems I just cant get the clamp tight enough when the oil gets cold and thick . I`ve had others to get it runnin again but need to be able to do it myself and dont remember the prosses . Can someone tell me how to get the dis. back in the right spot and do`es anybody else have this problem ?? Thanks
mEl
12-24-2001 13:05:29
 Re: Re: Timing - 480 in reply to Zach, 12-24-2001 12:32:03
If the distributor is properly installed, the rotor will point to number one spark plug when number one cyl is TDC at the end of the compression stroke, Obviously then #1 wire will plug in there, followed by 3-4-2 in a clockwise rotation as viewed from the top. the points should just break at TDC , that's basic timing,just to get it running, then time with a light. Your bushings must be tighter than normal or something mechanical is hitting to cause the distributor to move if clamped properly, it's running way to hard!!!!. mEl
