Case 300
glen smithee
12-04-2001 16:34:27
need info on how to change from 6-volt to 12- volt on 1957 case 300
Allan
12-04-2001 20:13:54
 Re: case 300 in reply to glen smithee, 12-04-2001 16:34:27
The explanations could take a bit. Firstly you probably want to use an alternator. Easiest is a Delco with the built in Regulator. This means Negative ground!. Starter should survive on 12 nicely. Amp guage doesn't care what the voltage is so all you may have to do is reverse the connections if the tractor was Pos Ground. ( I don't know what these are).Trickiest one is electric fuel guage. Will need a resistor of maybe 40 ohms in the line from the sender to the gauge. This is a bit general but you get the idea.
