Clutch D
Rick Huisman
02-19-2006 18:34:40
Can anyone tell me what the purpose is to have oil in the clutchhousing(as other makes don't have that)and also what level of oil will build up in there.What is the recommended time/hours between oilchanges?
Ken in AZ
02-19-2006 20:52:58
 Re: Clutch D in reply to Rick Huisman, 02-19-2006 18:34:40
Many clutches run in oil; look at automatic and powershift transmissions. It provides a coolant for the clutch as well as a lubricant. It also saves having to put a rear main seal on the Case tractors; many of these seals end up leaking eventually anyway. The part that isn't there doesn't fail.
The oil in them should be drained when the engine oil is changed. It will refill as the engine is run; not very tough to service.
Some models of dry clutches are rather difficult to replace the clutch bearing and require splitting the tractor. I'm not sure if the Case clutch bearing lasts longer or not... but I think it should, since as long as the engine bearings are getting oil, there should be some in the clutch as well.
Ken
