David Brown Hydraulic System
Mark
11-16-2001 10:29:15
Does anybody know if the 990 selectomatic hydraulic system is a closed center system or an open system? The reason I ask is I am considering building a wood splitter to run from the hydraulics and I don't know what type of valve to get. Any body have any suggestions about building this type of setup? Thanks.
Elmer
11-17-2001 05:27:06
 Re: Re: Re: David Brown Hydraulic System in reply to mEl, 11-16-2001 17:50:06
If looped through the couplers of the remotes it returns through the three point hitch valve and then to the transmission lube lines. If the tractor does not have a remote valve it can be plumbed into the manifold on the top of the axle housing and then put the 3 point lever into the select position.
