Price 830 case
johnny
10-29-2001 03:16:54
I am looking at an 830 caseomatic diesel wide front end. It runs shifts and drives fine . It is a 1966 The trans and the hyd are seprate. The trans fluid has a diesel smell and is milky looking the seat is bad the tires ara about 25% truck tires on front. It did not sell in the last auction the man said he wanted 2500 should I spend that on it Thanks Johnny
Dan Conine
10-30-2001 16:13:11
 Re: price 830 case in reply to johnny, 10-29-2001 03:16:54
Where are you located? I am in Wi. I bought an 830 with new rear tires for 1000 4 years ago. I had to fix a bent fork in the trans (dual range, not caseomatic). I bought a casomatic 830 that didn't run this year for 450.00, I rebuilt the engine and put new tires on it. I see 830's advertised for around 2500 often in this area. If yours needs tires, I would try to dicker down depending on what shape they are in. My caseomatic foams the fluid in the trans and makes it pink all the time. It works pretty good, though. For a case-o-matic, two things to check: Can you shift it into gear without grinding too much when it is hot, and does it move well in high gear without shifting into direct?
Alan Farley
10-29-2001 12:54:33
You are going to have to spend at least $700 for all 4 tires, so think of it as($3,200) instead of $2,500. If it doesn't need a overhaul and is in generally in good shape, I would definitly go for it. In the photo ads there is a 830 diesel for $4,800, I think it is priced on the high side for a narrow-front tractor. The other day somebody on this site was talking about how much a Ford 8N goes for theses days, for about the same price a guy could have more than twice the tractor, an 830.
