VAC oil level ???
Dale
10-21-2001 19:10:49
How do you check the oil level in the rear end and transmission on a 44 VAC. I can't find any plugs on the side except one up near the steering box. Thanks for any info.
Tom Harrower
10-21-2001 19:39:25
 Re: VAC oil level ??? in reply to Dale, 10-21-2001 19:10:49
Hi Dale, the VAC has a dipstick that is attached to a square headed plug on the same plate on top of the transmission that the shifter is in. If you unscrew the plug next to the shifter you should have a dipstick on it with a mark indicating the correct oil level for the trans and differential. A VAC transmission and differential will take 7 gallons of 90 wt oil when compleatly drained. Good luck..... .Tom
Mike from Canada
10-21-2001 19:30:35
There should be a big square head plug on the top of the transmission just ahead of the shift lever. if you remove it you will notice a rod welded to it with a graduation mark. It should take approx. 8 quarts.
Duane(Pa)
10-22-2001 18:09:31
 Re: Re: VAC oil level ??? in reply to Mike from Canada, 10-21-2001 19:30:35
Those must be the big'ol IMPERIAL quarts I hear'd about at the fair?
Duane(Pa)
10-23-2001 16:34:43
 Re: Re: Re: Re: VAC oil level ??? in reply to Mike from Canada, 10-23-2001 05:55:53
All for fun. Unlike the flames about generators.
