Re: Super L Case Modify
Fordson29
10-17-2001 06:04:02
manifold@smig.net e-mail Don he seems to know a whole lot more about a Case then anyone else He also may have some parts for you. I am sure they made a LP head for yours maybe he will have one. If not I would shave it port it port your manifold and go with a bigger carb. or change the venturi size and jet size. You just need more airflow threw your engine. When you increase air flow then you can increase fuel flow with out flooding it. You should then put some hot plugs in it Maybe a MSD box to increase your spark. You then should have pretty good power take it to the pulls and then you can learn how high of a weight class you can go.
