DB 990 implematic 12 speed PTO input oil seal
David Coonan
10-15-2001 22:27:17
Hi, I have a question on DB 990 12 speed (1964 model ser. no. 466002) I want to replace the oil seal on the PTO input drive shaft to prevent oil getting in the clutch. I have the tractor split to replace the clutch, if I remove the transmisison cover can I get enought of the creeper transmission off the front of the 6 speed part to replace the PTO input drive shaft oil seal without taking the complete transmission out of the case? (I am aware I need to remove PTO unit and diveshaft from rear.) Thank you for any help youmay be able to give. Dave Coonan
Elmer
10-16-2001 16:16:36
 Re: DB 990 implematic 12 speed PTO input oil seal in reply to David Coonan, 10-15-2001 22:27:17
I don't think there is enough room for the creeper gears to move ahead. After taking the lid off, it is not that much more work to undo the rear axle casing from the transmission housing, and move the whole assembly back. Makes it easier to work on too.
