VAC carburator
Randy Hamilton
10-11-2001 14:23:25
A friend is needing a float for a VAC carburator.
Can't find any #'s on carb. for identification.
Any help appreciated. Thanks
Joe(Wa)
10-11-2001 19:11:49
 Re: VAC carburator in reply to Randy Hamilton, 10-11-2001 14:23:25
Randy, If the carburetor is original equipment it will probably be a Marvel-Schebler TSX-114. You should be able to see "MARVEL/SCHEBLER" cast on the bowl in raised letters. There should be a teardrop shaped brass tag on the carb intake throat opposite the choke linkage (dead end of shaft) stamped with carb model TSX-114, TSX-597, etc. The last overhaul kits I bought from a Case dealer is listed on the receipt "TX-C554 CA CARB REPR KIT $24.95". This a TISCO generic kit for these carbs. I also have a new float assembly for a TSX-114 with p/n 9N9550A but don't know the mfr. Some VA series had the Zenith carb. I have no experience with these. Good luck, Joe
