Case 530CB back hoe loader tractor
screaminghollow
09-21-2006 17:25:14
I"m looking at an old Case diesel. It hasn"t been run in about 8 years. The hour meter says 26769, which seems like too much. The owner recently passed away. What kinds of things should I be looking at, to determine whether it can be resurrected. Starter looks all corroded and I doubt it will work. Not sure what the estate wants for it, figure if it is cheap even a new engine might be worth the cost. One cylinder on the boom will definitely have to be redone.
Mike Veen
09-29-2006 09:31:34
 Re: Case 530CB back hoe loader tractor in reply to screaminghollow, 09-21-2006 17:25:14
Buy it cheap and if it's not worth fixing .Part it out.You can get alot for trans parts, cranks etc.if you have the time and place of course.
BKahler
09-23-2006 06:19:58
I recently resurrected a 1963 530CK backhoe(George helped a bunch on this one!). I got it for a really good price which was the only reason it was worth rebuilding. The engine needed a new crank, one rod and a whole lot of other work. All of the hydraulic cylinders ended up neededing rebuilt and/or replaced. Most of the hoses have had to be replaced. After it was all said and done we barely came out ahead compared to what it would have cost for a backhoe in better condition to begin with.
If I had to do it over again I'd look for a better one to start with.
But now that its done it does work great and it gets used all the time.
Brad
george md
09-21-2006 20:36:13
Is that tractor in woodbine , pa ?
george
screaminghollow
09-22-2006 03:03:39
 Re: Case 530CB back hoe loader tractor in reply to george md, 09-21-2006 20:36:13
about fifteen miles further, New Bridgville, PA, York County
george md
09-23-2006 11:04:37
 Re: Case 530CB back hoe loader tractor in reply to screaminghollow, 09-22-2006 03:03:39
Did you buy it , heard it brought 1350 , the tall dark hair fellow ( the junk yard ) said he talked to the fellow that bought it .
george
