Updraft carb freezing problem
Bob
10-08-2001 04:14:03
I own a case 450 crawler with a gas 166 engine.
It has a updraft carb and when it is cold the carb can freeze off at hr connection to the manifold. Any ideas how to prevent this? Thanks!
tim
10-11-2001 17:55:20
 Re: updraft carb freezing problem in reply to Bob, 10-08-2001 04:14:03
Just curious, Do misadjusted valves cause this trouble? My DC did that when I got it and I adjusted the valves(they were VERY loose) and I haven't had that problem again and it runs MUCH better. Is it just luck or the solution?
C. Amick
10-08-2001 14:12:10
I bent a piece of flashing around the exterior of the vertical manifold pipe and left it open on the side toward the engine on my Case 311. The idea was to collect heat off the engine block. It doesn't prevent the problem, but it seems to help. Also, most of the time if you shut the engine down and let the ice melt, it doesn't ice up as bad when you start back up.
