What's the trick?
Huckelberry
10-07-2001 20:04:48
I can't stop gas from leaking out of the sediment bowl. I was thinking that the cork gasket was getting dry after sitting with the gas off. I tried a "paper" gasket and it worked for 3 or 4 days before it started leaking. Is there a trick, or something else I can try? I'm starting to wonder if the glass bowl is the wrong size or something.
Huckelberry
10-08-2001 20:24:55
 Re: What's the trick? in reply to Huckelberry, 10-07-2001 20:04:48
Thanks everybody. I'll try a neoprene next, if that doesn't work, I'll replace it. I'm getting tired of buying cork gaskets and wtching it drip, drip, drip ...
joe-tx
10-08-2001 20:16:49
On mine, the little ears on wire were straightened too much. I took some pliers bent them down a little. It tightened up better.
Pat T
10-08-2001 03:51:22
NAPA sells replacement neoprene bowl gaskets that end this annoyance for good.
Pat
George S. in the real NY
10-09-2001 03:36:13
 Re: Re: What's the trick? in reply to Pat T, 10-08-2001 03:51:22
Hey Guys, I had a leaky fuel bowl on my 530. Made a gasket out of kinda thin gasket mat'l, all that I had at the moment, still seeped. Got one of the the NAPA gaskets, no better, still leaked. Tried this: put the gasket mat'l one between the housing and screen, and the neoprene one between the screen and bowl. It has been a week now and it is not leaking. If I do it again, I'll use thicker, 1/8 in material. For now..... .
Bill
10-07-2001 23:04:18
The housing is probably pulled out of shape a bit but a paper gasket just won't do. A fresh cork gasket is your only hope.
klyde
10-07-2001 20:39:10
Its warped!!! Sombody tigtened it too tight and warped that high quality potmetal. Buy a new one and take it easy on the tension.
Larry
10-07-2001 20:30:52
I've gone through the same thing a few times. It got so I was afraid to touch the darn things. The best solution I found was to buy a sediment bowl gasket. I'm sure the dealers have a few in stock. I found the ones I got at a Farm & Fleet store.(BTW I'm the same Larry who posted at the Kountry People page)
