Play in distributor of a VAC
Jim in Wisconsi
10-05-2001 19:44:09
I have the opportunity to buy a 1940's VAC that runs but has "play in the distributor" according to the owner. It seems to vibrate when the tractor is running.
How much would this cost to fix and how big of a job would it be?
Jim
10-07-2001 04:44:58
 Re: Play in distributor of a VAC in reply to Jim in Wisconsin, 10-05-2001 19:44:09
I had to replace the bushings in the distribritor on my 500B this summer which is the same, The bushings were .35 each and was an easy fix, I pressed out the old ones,pressed the new ones in and used emory cloth twisted up to hone to fit.
Jim Yadon
10-06-2001 03:49:37
If it is anything like what happened to me it could be expensive to fix. It could be several things. One it could be the internal parts for the distributor are dry and stiff. The second most it could be the bearings are starting to wear severly and starting the cam shaft to waller and get out of balance. Which in turn causes the gears on the cam and the distributor to not to mesh together properly then which causes the shear pins to shear. Which causes metal shavings. Which causes damage to bearings. So on and so on!!!! Then this pretty much means complete overhaul while you are there. Been there and done that!!!! Pull out the distributor and check the bottom gear and so how much wear there is. It really should not be damage to the gear because it does not engage or disengage. Hope this helps. Good luck
