How to Stop an SC?
C. Amick
10-01-2001 13:06:50
I just purchased a 1949 Case SC equipped with a magneto. A lot of the wiring is missing. There are two push-pull switches on the dash. One is probably a light switch and I assume the other is an ignition switch. I don't see anyway to kill the magneto with a switch though. There doesn't seem to be an external wire connection on the magneto.
Mike Hodges
10-08-2001 16:38:49
 Re: How to Stop an SC? in reply to C. Amick, 10-01-2001 13:06:50
There should be a small nut on the back of the mag. The wire attaches to this stud. When the switch is pulled out it kills the tractor and when it's pushed in the mag is on. HTH...Mike
Kirk in Oregon
10-03-2001 07:22:15
I have an original SO with Case mag still on it. There is a ground terminal on the mag. Wire runs from that to the switch by the starter button, as the other respondents have described. The kill switch and the light switch are the samepart I think; the "out" position is closed or what we think of as ON and the "in" position is open or OFF. It's just kind of confusing with a ground wire. You turn ON the switch to turn OFF the tractor! With the lights, of course they come on as would be expected in the out position. Just as a safety factor, please don't attempt to operate the tractor until you figure out a way to hook this up to your magneto. Good Luck! Kirk
Larry
10-01-2001 23:22:20
The push-pull switch near the starter button is for the mag. Just one wire goes to the mag terminal. When the switch is "in" it is on. When the switch is "out" it is off. Providing the tractor still has the original switch on it.
I put a lot of hours on many a SC,and can still remember pushing the mag switch in with my toe,and then stepping on the starter button to get them started. When you wanted to shut the tractor off you had to reach down and pull it out.
