Case vac
bob g
09-28-2001 08:38:22
i have a 1950 vac that broke the oil pump and spun a rod and main bearing. my question is the main spun a little is their a way to get the new bearing to stay in with out spinning again. line boreing is to expensive around here .
anonymous
09-28-2001 15:33:12
 Re: case vac in reply to bob g , 09-28-2001 08:38:22
I'll tell you how, but you didn't hear it from me. I've cleaned up a lot of these messes. Take a brass tubular rivet and drill a hole all the way through the head, to let the oil through.Then put it in the main with the stem in the oil hole. I've seen them run for years like that...
bob
10-02-2001 10:46:54
 Re: Re: case vac in reply to John, 09-28-2001 12:46:22
im up in ny i think its a little to far . i think ill try the rivot idea it makes a lot of sense.
