480f problem with Brakes
Jeff Ford
02-16-2006 05:26:18
I just purchased a 1990 480f and in order to stop the machine I have to press the brakes to the floor to get it stoped. If I'm running at 1500 RPM I can barely stop the machine. I looked through the operators manual but couldn't find that there is any adjustments that I could make. What should be the first thing I should look for?
oakleys pappy
02-16-2006 06:57:23
 Re: 480f problem with Brakes in reply to Jeff Ford, 02-16-2006 05:26:18
Did you check the brake fluid level and bleed the brake lines?
