David Brown 990 no start
rod
09-06-2001 13:36:42
Hi all here is my problem I bought a 990 Implematic that I did not hear running the engine turns over fine, has fuel to injectors and seems to have compression but still will not start. Any ideas not sure if previous owner had it apart but there is silicone on the front cover. I turned the injectors upside down and they all cracked open and sprayed fuel.
thanks
rod
kraig
07-07-2003 22:16:31
 Re: David Brown 990 no start in reply to rod, 09-06-2001 13:36:42
Take the pump loose and turn it 180 degrees, pray he doesn't have the rest of the timing screwed up.
I've seen it where these guys who do alot of pumps, if the tractor don't start after bleeding, line up the marks on the pump, take off the pump spin it 180 and put it on, u might have to use the timing marks on the flywheel, I am not sure if CAV pumps have lines to line up like roosamaster. Saves breaking valve cover gaskests, taking off hood and all that.
Paul Chetland
10-18-2003 13:59:52
 Re: Re: David Brown 990 no start in reply to kraig, 07-07-2003 22:16:31
Firstly my ignition switch is intermittiant.
I have volts at the solenoid but the starter still won't engage.
There is a lot of wires behind the dash going nowhere.
has anyone got the wiring diagram for a 1970ish DB990 so I can tidy up someone elses mess before I pull the starter apart?
Ronnie Thomas
09-06-2004 16:51:59
 Re: Re: Re: David Brown 990 no start in reply to Paul Chetland, 10-18-2003 13:59:52
I have a david brown model 990 that I just replaced the stater on due to it staying engaged after starting. I also checked the swith and all the wires behind the swith were burned. Looking for a wiring diagram for this. Any help would be greatly appreciated.
