VAC electric system
scott
07-24-2001 06:10:56
We bought a VAC from an auction and I have to questions. My first is how do you know if a tractor has been converted to a 12-volt system? The guy that owned it started to restore it but it looks like he gave up and threw it together to put it in the auction. It has a new battery in it, we can't find where it says if it is a 12 or 6 volt. If you put a checker on it, it reads 12-volts. But on the side of the regulator on the case it says 6-volts. But the tractor starts and runs pretty good. The generator isn't hooked up, so maybe that's why there aren't any problems. that leads to my next question, does anyone know where i can get a wiring diagram for my case?
Thanks, Scott B.
Lew
07-24-2001 19:35:10
 Re: VAC electric system in reply to scott, 07-24-2001 06:10:56
If what you refer to as a regulator sits on top of the generator it is not a regulator but rather only a cutout relay. The rate of charge is controlled by the position of the headlight switch. If it is 6 volt it will fry if the generator is putting out 12+ volts which it will if it is connected to a 12 volt battery. The cutout relay disconnects the generator from the battery when the generator voltage drops below the battery voltage. The other problem that 12 volts will give you is a saturated ignition coil which will not fire the plugs properly. A 12 volt coil or a dropping resistor will cure that problem. As to the cutout relay, a 12 volt one may be available or I have seen a starter solenoid used instead. You want it to engage when the generator voltage exceeds the battery voltage and disconnect when the reverse is true. I used a 50 amp solid state diode ( observing proper polarity) Hope some of this helps. If you want feel free to e-mail me and I can go into more detail if you like. Lew
