Need advice on broken sparkplugs in heads
Tom in Mo.
07-22-2001 18:02:52
Tried to remove sparkplugs on '65 830 CK and broke off 2 out of 4. The centers twisted out of the threaded shells. Any tips on removeing the shells without removing the heads?
ferrell freeman
07-26-2001 11:27:10
 Re: Need advice on broken sparkplugs in heads in reply to Tom in Mo. , 07-22-2001 18:02:52
In the the past when I,broken sparkplugs off. i, try easy out if that didnot work then try daimond point or cape chisel ,one thing use penatrating oil and let it soak for several hours .The welding a nut will also work the green rod is rod tunsten alloy rod .This can be done one of two ways the nut or a peice of black iron pipe that will fit in side of the remaining plug .
Chuckles
07-23-2001 05:19:49
Risky job without removing heads,sorry, you likely would wind up only having to Helicoil the holes. This is not a good way to go. Head shop likely would be your safest mode. We tried a couple of these in our shop in the past.Bad results!
Chris Vangel
07-22-2001 22:52:59
Tom, in the past I have seen this happen in cars. If you mean that the only thing stuck in the hole is the threaded barrel of the spark plug, you could try a #5 or #6 easy out. I have had luck trying this in the past. The only other option, and I am not brave enought to try it, is to weld a bolt to what is left of the plug and try to unscrew it the usual way. The father-in-law is a welder and says they used to use some kind of 'trouble rod'. It apparently is pretty tough stuff and can resist the turn force needed to remove broken bolts. That's all I can think of this late at night. Good luck. Chris Vangel
