1030 case
Earl
07-11-2001 17:56:51
Can anyone tell me what is the most horsepower you can get out of this tractor by just turning the pump up leaving everything else original except for a for fixing ups here and there
John H
07-12-2001 06:06:28
 Re: Re: 1030 case in reply to jeff, 07-11-2001 19:35:23
I was told by a neighbor when he was still living and worked as a sales person for a nearby John Deere shop that they turned the pump up to 150 hp on the dyno for a farmer cause he wanted to be able to use it on the same equiptment as his big John Deere. He said it would pull the plow just as easy when they tested it. You can only try.
Thanks.
maybe a 105 HP 1030 out pulls 150 hp JD..
07-14-2001 05:07:30
 Re: Re: Re: 1030 case in reply to John H, 07-12-2001 06:06:28
Maybe the 1030 just pulled so well that the only way the JD's could keep up was to have a 150 hp JD, and the folks did not want to admit that the Case was only 105 hp...
peggy
07-02-2002 09:10:05
 Re: Re: Re: Re: Re: 1030 case in reply to JDkid39, 07-17-2001 22:03:17
we just purchased a Case 1030 - need to know what year and best place for parts
Jeff
07-25-2001 11:05:59
JDkid39,
i was wondering if you knew anything about if case had a gas head for 401, 451, or 504 motor maybe in an industrial type engine. thanks jeff
