David Brown 990 fuel line
J. Curtis
05-20-2001 12:03:24
We recently got a David Brown 990 diesel. It has been running fine. Yesterday my husband left it idling when company showed up. When he went to drive it again, it died and would not start. A friend that knows tractors came to look at it, removed the fuel line before the bowl, and there was only a small drip coming from the fuel tank. The fuel tank is full. We can blow air backwards into the tank, but still only a drip comes out. Friend said to drain the sediment out of the tank. Is that what is wrong with the fuel line? How do we get the top of the tractor open to get at the tank?
J. Curtis
05-20-2001 16:00:02
 Re: Re: David Brown 990 fuel line in reply to Pat T, 05-20-2001 15:06:13
Thanks for both of the excellent suggestions. I have just received a warning from another tractor owner not to pump any more fuel through the line until I can get the fuel filters off and changed, or rust may get into the rest of the system. If I get the fuel filters off, can I buy that size at a local parts supply store like Napa? Also, should I still try to find a way to drain the fuel tank to get rid of the rust? Is there an additive that we can use to put in the fuel tank to kill the rust so we won't have to drain it?
Pat T
05-20-2001 18:56:26
 Re: Re: Re: David Brown 990 fuel line in reply to J. Curtis, 05-20-2001 16:00:02
Napa has the filters, their number is 3166. There should be a drain plug on the bottom of the tank more towards the left side you can remove if you feel the fuel is old or contaminated, probably a good idea to pull it anyway in case there is water sitting on the bottom. Someone else may have a suggestion on the rust inhibitor, most of the tank sealers I know of require you to remove the tank so that it can be turned every which way while the sealer is in it to coat all of the interior. Get yourself an operator's manual if you don't have one, filter changes and bleeding the fuel system are well covered there, and sounds like you're going to need to do both.
