Re: David Brown 1200 Valve train
gr in ny
05-03-2001 20:55:17
Had a customer with a 1212 that broke ALL the gears in the timing cover. Called a salvage place for gears and the replacement gears that were sent were all the same diameter, but the mesh of the teeth was much finer. Called salvage yard back and they had never heard of such a difference. Gears fit right up fine, timed up perfect, and is still running every day. I wonder if DB had a problem with timing gears and addressed problem by providing more teeth (finer teeth) to absorb the shock loading present in these engines. Also it bent 2 pushrods. Pulled the head and nothing was bent, so threw valves back in, installed gears and away it went. My experience.
