VA versus VAI
Momac
04-03-2013 04:32:38
What"s the main difference between a VA and a VAI? Thanks, Mike
Momac
04-04-2013 12:58:40
 Re: VA versus VAI in reply to Momac, 04-03-2013 04:32:38
THANKS GUYS. One thing I noticed on the VAI I'm looking at are the front hubs which seem pretty heavy duty. Mike
NickatKY
04-04-2013 18:44:38
 Re: VA versus VAI in reply to Momac, 04-04-2013 12:58:40
If it has the bigger front hubs it's probably a 1950 or newer and has the rear end casting for eagle hitch if you wanted to put it on.
Nick
NickatKY
04-03-2013 18:16:45
Here"s a few more differences between a VA and VAI
The easiest way to tell them apart is a VAI has the headlights on the sides of the grill and a VA has them mounted to the front of the floorboards or later models in front of the gas tank.
The shift pattern is different on a VAI/VAIW than any other VA series.The VAI is 1,2,3,4 instead of 1,3,2,4
VA"s had 24" rear rubber until the mid 40"s all VAI"s had 24" rear rubber
VAI"s have a small lever on the throttle linkage to limit engine speed when using pto. My 48 VAI will run 18mph.
The were several different axles used on the VA/VAI"s over the years
Nick
wheat straw
04-03-2013 07:11:00
mike,
The va is essentialy a vac with a straight fixed steel axil on the front end with a riser on the monting point to keep the normal height for a vac. The rear axil is a bar axil that the normal 28" clamp on cast hub bolts to but the axil is short, no adjusting the rear tread on the axil. transmission, bull gears, ground speeds all the same as a vac.
The vai is an industrial version. Normaly, straight steel axil on front without riser to lower it to the ground. the rear has flange axil with 24" wheels to level out closer to the ground. The bull gears were different giving a high road speed and the working gears are faster. Some of them move fast enough to blow your hat off on the road. My brother has one he rakes with. Second gear half throttle is plenty fast for the old farm hand right and left rakes. Road gear gets you to the next farm in a hurry. Therre are always variations. I have seen the vai with the short bar axil and a 24" clamp on hub that looked like a vac but obviously closer to the ground. You can just never say never.
Wheat Straw
