bought a burned 1070 and need help
Peter sask
04-02-2013 18:54:40
Hi guys I am Peter from Saskatchewan and new to this forum and tractors and hope you can help me.
I have a 1070 that had a fire under and in the cab at the right side.It melted hoses and wires.
My problem is the return line from the steering(the plastic line that runs on the right along the engine block) to the transmission.I cant for the life of me find where it goes on the transmission.
I have a later model 1070,white,with powershift and hydrostatic steering and hydrolic brakes if that helps.
Oh and if anyone can tell me where I can find mastercylinders that will be great.
Thanks
Peter
Peter sask
04-03-2013 17:19:10
 Re: bought a burned 1070 and need help in reply to Peter sask, 04-02-2013 18:54:40
Thanks 1370 Rod.I found it !!
Now I have another issue.
When I let it idle and select a range,I cant get it to go in reverse,when i leave it no1 of the powershift and let the clutch out its like it wants to move but then nothing.I also have no steering.I just put a seal kit in pump/steerbox under the dash,but now its leaking from the bottom part of it.
I have no wiring in it at the moment but that should not matter or would it.
Thanks
1370rod
04-02-2013 19:35:49
That line connects to the trans top cover on the RH side also. The fitting is directly above the flowdivider valve, its sort of hard to see and its tough to get a wrench on the nut but possible, takes a 5/8.
Peter Sask
05-22-2013 18:21:09
 Re: bought a burned 1070 and need help in reply to 1370rod, 04-02-2013 19:35:49
Hi guys have a new problem.The steering is almost impossible to turn,hard like something solid.I see can a little movement in the steering arms but hardly any.Any ideas?
another question:I have two brake master cylinders but right above them is something in the hydrolic line,looks like a T-piece.Could that cause a blockage?
Back Ground:I did buy it burned and replaced all burned lines,the steering motor under the dash and it has enough oil in the trans.It runs good starts at a touch of the key.The front end loader work,trans oil pressure is in the green.
