Vac starter spring broken, is there a fix?
greg M
04-25-2001 16:23:51
On my Case VAC the starter has a large spring behind the gear. this spring is broken. I assume it takes some initial impact as the starter gear meshes with the fly wheel. Looks expensive if i can still get it. Any alternatives? if i couple the two together, will i break the teeth. running 12 volt system.
parts source?
thanks
klyde
04-26-2001 04:36:20
 Re: vac starter spring broken, is there a fix? in reply to greg M, 04-25-2001 16:23:51
get a new bendix for it , instead of a spring. that will handle the 12 volts better.
Lew Van Vliet
04-25-2001 20:33:03
I had my VAC's starter reconditioned at the local auto parts store (CarQuest) Case purchased the starter from some other company (Delco, Autolite, etc) so repair parts should be available. Happy hunting.
