Power steering pump update
Dennis/Ohio
04-21-2001 04:12:58
Couple pages earlier Butch Keiper identified the pump I have as off a 600 or 660 combine. I did hard plumbed both pump outlets together so they share one relief valve. Seems to work fine. I'm only running 800 psi but I probably won't shim it higher if gets around ok. Also I learned the two return connections at remote resevior have very different flow capacities. With the hoses switched it runs 400 psi all the time. The previous owner had it connected that way and I'm assuming thats what cooked the other pump. Thanks for the help, Dennis.....
