Hydreco valve unit
Tim Williams
04-04-2001 10:03:33
Is there any info or drawings to aid in rebuilding a Hydreco valve assembly for a Case 530CK Backhoe? Also, when replacing a hydraulic hose is it nessesary to bleed out the air? If so, how do you do that? Thanks for any help!
Tim
Dennis/Ohio
04-08-2001 05:44:48
 Re: Hydreco valve unit in reply to Tim Williams, 04-04-2001 10:03:33
Tim, Air will bleed as you use it but can be very dangerous if alot of air got in cylinders. Air will compress then the unit will jump. I recommend service & parts manuals from this site. Tractor, loader & hoe model & serial are needed to get correct manuals. 530's had many updates during production and serial number is the only way to find correct parts. Hope that helps, Dennis....
