DC Case
Wayne
03-20-2001 08:01:39
Just looked at a DC for possible restoration. I was unable to locate an I.D. plate to check the serial number. I believe it's supposed to be under the battery on the dash. I did find a rust spot with two protuding screws on the dash. Is this the correct place and can the year model be found someother way? Restoreable tractor but way overpriced. Mismatched tires, Eagle Hitch arm torched off, missing fenders amoung other things. I do like the single tire front end. Not knowing the serial number kind of scares me away from it.
Thanks Wayne
dcpuller
03-21-2001 14:54:01
 Re: Re: DC Case in reply to Roger A., 03-20-2001 15:54:13
If it has the eagle hitch then its a 53 or 54 . they put the hitch on the last two years they made them also some 54's had foot clutches.
