Case VAC oil pressure and oil filter
Dan
03-19-2001 17:52:24
I have a 1952 Case VAC that we have just restored. We got it all together and it fired right up. Looked at the oil pressure gauge and it is at about 10 psi on a 0-60 gauge. What is the correct oil pressure for a VAC?
We also have a new oil filter for this VAC and it has a wooden stick in the middle of it. What is this wooden stick for? Should it be left in the filter? The Filter is a NAPA brand.
DALE
03-20-2001 19:06:35
 Re: Re: Case VAC oil pressure and oil filter in reply to Joe (Wa), 03-19-2001 22:12:11
Joe, If the filter is an option,can it restrict oil flow to top of engine? Does oil flow through filter first? Just curious as to its purpose! DALE
Dan
03-20-2001 03:58:42
Thanks Joe. I must be missing the inlet tube in the oil filter housing. I can see that without it the oil would never go through the filter. I do have a NAPA 1104 filter. Thanks for your help.
