Using a IH Farmall H magneto; is it a Good Idea?
ThatOtherGuy
03-19-2001 12:40:18
I'm planning on using our old H magneto on my Case SC. Would it be a good idea? The H has been converted, so the magneto isn't in use right now. I held it on, and turned the NOW FREED ENGINE by hand. It works, and I want you guys to think about it. There wasn't anything I had to do for it to fit..EVEN THE HOLES LINE UP!!And I wonder where I can get a 3 1/2" sleeve for piston #4, since they claim they can't get them down at Fuselines Case IH....
Later, ThatOtherGuy
Scott
03-19-2001 14:50:41
 Re: Using a IH Farmall H magneto; is it a Good Idea? in reply to ThatOtherGuy, 03-19-2001 12:40:18
That magneto should work just fine since as you stated the mounting flanges are a standard fit. I am currently running a mag from a Wisconsin 4 cyl.on my SC since caps are no longer available for my otherwise good Case mag. As for the sleeve, good luck!
