DC clutch sticks
Richard
03-11-2001 06:58:58
I have a 1953 case DC with a foot clutch All a sudden the clutch started sticking after the tractor sets even for a short time {30min}. The clutch housings has oil in it,I have spreaded BP blaster on the pressure plate, burned the clutch a little in forth gear. Both seems to help for a short time. This requires me to start the tractor in gear then brake, once I do this the clutch works correctly until I shout the tractor down for a while then it sticks again. This is a pulling tractor that gets plenty of use. Any ideas?
dcpuller
03-22-2001 14:20:54
 Re: DC clutch sticks in reply to Richard , 03-11-2001 06:58:58
not familiar with the foot clutch but I know that if mine sets for a few weeks without use the cluth will stick or is grabby. I found that if I leave it engaged during storage that it won't stick .what class do you pull and are you doing any good. I run 5500 farm .
klyde
03-12-2001 04:59:33
You prob won't belive this but--- we had one doing exactly the same thing, started shortly after a new clutch disk was installed. After much screwing around an OLD mechanic told me it was the rivets!!!! I did what he said and it worked, take the smallest drill bit you have and drill all the plate rivets, it seams they make little hydrulic cylinders with the engine oil in them and when they cool down they lock to the flywheel.. worked for me..
