What kind of Case have I found???
Gary
03-05-2001 15:32:34
Last week I found an old fence-rowed Case tractor. I contacted the owner and he would like to sell it but he doesn't remember what model it is. It is the traditional Case orange and tan color. It is Marked "300 Diesel" on the side pannels, but it has a 4 cylinder gas engine. The tractor is close to the same pysical size as a 8N Ford. It has a wide-front-end; the steering rods are all in front of the axle, and the steering box (looks like power) is under the raditor. It has a 4-speed transmission and also has 2 other shifters between the operators knees. It has a 3-point hitch and there is lever that pulls up and down mounted near the PTO output shaft. It also apears to have a differential lock and there are hydraulic hoses on the machine. The owner said the engine started knocking (he guessed the bottom end) while brush-hogging and he shut it off and there it has set for at least 4 years. The tires are flat, but the tread is good. The best I can tell the machine is complete, except that the hood is missing. I grew up around Masseys and Fords and know very little about Case. What have I found and what is worth??? Any help would be grealy appreciated. Thanks!!
