Injector cleaning
rod
02-27-2001 07:59:29
I have a DB 990 1962 Implematic it will start on ether but won't run for long there is fuel at the filters, the injectors, and pump is pumping it pretty good. Now my question the tractor has been sitting a few years can I just take out the injectors and clean it up or are they set at a certain setting. I have no knowledge of deisel injection systems
regards
rod
Elmer
02-28-2001 04:12:38
 Re: Re: injector cleaning in reply to david, 02-27-2001 10:22:45
Turn the engine over while bleeding the air out of the injector lines. Also the push rod between the camshaft and hand pump is prone to wear. If the tractor runs and quits under load tthat is the first place to look. The push rod is no longer available, but i have some in stock.
