Possible clutch problems
sonny
02-15-2001 20:39:56
i have a sc with a hand clutch.
when i let the clutch out i have to put continous
pressure on clutch to keep tractor going.
is there any way to adjust clutch if adjusting pin
is missing. could there be some other problem.
i need help.
Larry
02-15-2001 23:03:49
 Re: possible clutch problems in reply to sonny, 02-15-2001 20:39:56
Are you talking about the two pins on the adjusting collar,that you pull out when you adjust the clutch.If they are missing you probably won't be able to adjust the clutch properly.
