Re: Icing Carburetor
C. Amick
02-06-2001 09:47:47
OK, here's what I think is the cause of the icing problem and what I did to help the problem on my 300. I think the icing problem is caused by the long intake pipe between the carburetor and manifold. I cut a piece of aluminum flashing and bent it in a "U" shape around the intake pipe and upper part of the carburetor. The open side is toward the engine block. I wrapped a wire around the pipe and brought it out through two small holes in the flashing to hold it in place. It seems to minimize the icing problem. It also helps it thaw out faster by collecting heat from the engine block.
