DB1200 diesel; hard starting
Paul
02-05-2001 11:35:17
I have a DB 1200 diesel with a simms injector pump that is very hard to start. Once it does start, it runs ok with good power. I have replaced the diaphram in the lift pump with little effect. I am looking for the most reasonable order of action. Compression (how? as I have never checked on a diesel) Injectors? Valves? Injector pump? Pump timing? I also have a 990 with a cav pump that starts like a gem. Any Ideas would be greatly appreciated.
Elmer
02-05-2001 17:29:25
 Re: DB1200 diesel; hard starting in reply to Paul, 02-05-2001 11:35:17
I would pull the injectors first and make sure you have proper atomization. Break off pressure should be in the neighbourhood of 2500 psi. Adjust valve clearances at .010, If you have bad compression their should be alot of blowby evident.
