Problem lubricating rockers
Ron
02-02-2001 13:20:19
'54 SC-4 I can't get oil to the rocker arm. I've disassembled and cleaned everything including the pipe coming up from the block. I've pulled the oil pump and replaced the shaft, relief spring and plunger. I've got approx. 25 psi oil pressure. What's left to do? HELP
Joe (Wa)
02-05-2001 22:32:42
 Re: Re: problem lubricating rockers in reply to C. Amick, 02-05-2001 10:11:11
Mr Amick is correct re the spindle (tube) missing in the filter housing dropping the oil pressure at least 50%. The original tube is about 3/16" od x 4" long and is pressed into the base of the holder. They tend to get stuck in and pulled out/discarded during filter change. On a VAC & a 311b I have drilled the base and pressed in an appropriate length of 1/4" copper tubing (interference fit) or you can hunt up a piece of sized brake tubing that will press in w/o drilling.
klyde
02-06-2001 04:56:18
 Re: Re: Re: problem lubricating rockers in reply to Joe (Wa), 02-05-2001 22:32:42
SC's don't have that style filter but thats not saying there isn't a problem there too. none of my S's have an external filter, so you could probably plug the line to the filter and then see if you have oil up to the rockers.
