VAC throttle
gregory
01-23-2001 15:38:11
Does anyone have a diagram or photo of a VAC hand throttle assembly? My VAC has the foot throttle and the linkages for where a hand throttle would go. It also has a "half-moon" plate on the stearing shaft but it swings around whenever the stearing wheel is turned. Thanks.
Mike from Canada
01-26-2001 11:02:32
 Re: VAC throttle in reply to gregory, 01-23-2001 15:38:11
If you look in an IH Case parts manual, it should give you an exploded view of the throttle linkages. Depending on the year, The hand controls should either be a bell crank handle ("L" shaped) or a "quadrant" plate. It would help to know the serial number of the tractor to identify the application.
