DB 1200 steering problem
Tim Daulton
02-05-2006 13:56:33
I have a 1971 DB 1200. Great old Tractor but I have a steering problem. Steering seems to slip like it has bad cogs. Pump is good and so are cylinders (no leakage anywhere). Could my problem be at the steering column base? If so can it be rebuilt?
Tim Daulton
02-05-2006 19:31:50
 Re: DB 1200 steering problem in reply to Elmer, 02-05-2006 18:44:33
I had that cylinder professionaly rebuilt. I am wonder if the fluid is bypassing in the box at the end of the steering column?
Tim Daulton
02-06-2006 17:15:33
 Re: DB 1200 steering problem in reply to Elmer, 02-06-2006 04:23:49
That sounds like a good test. If it does turn can the hand pump be rebuilt?
JRT
02-06-2006 09:47:27
 Re: DB 1200 steering problem in reply to d masters, 02-05-2006 14:38:17
My 1200 wandered for years until I finally decided to fix it. Had the cylinder on the outside that connects to the steering arm rebuilt. Didn't cost a lot. Old David drives like new now. Wish I had done it sooner. Now I can roll hay all day without wearing my shoulder out.
