JI Case 1030
Steve
01-20-2001 15:00:34
I am having fuel problems with my Comfort King. I
believe someone rerouted the fuel lines from the
original setup. Does any one have some pictures or
schematics of how the lines are supposed to be
hooked up? The bleed off lines go all the way back
to the tank, is that right?
Steve
01-24-2001 17:16:31
 Re: Re: JI Case 1030 in reply to JEFF, 01-23-2001 13:40:45
Jeff, I got the bit map. Sure enough the fuel
lines are hooked backwards. No wonder the engine
was running in reverse.
Steve
Steve
01-22-2001 17:12:22
 Re: Re: JI Case 1030 in reply to JEFF, 01-21-2001 07:36:18
When the fuel gets below the return line, the
engine will die. I suspect that the lines have
been short circuited. The line out of the fuel
filter goes into the rear of the injector pump.
The #1 injector bleed line goes into the front of
the injector pump. The bleed line off of the #6
injector goes into the tank. I think it has been
pulling fuel right out of the tank from the bleed
line into the injector pump.
Steve
