830 CK 3 point problems one more time
Rick Wages
09-20-2006 18:26:33
3 point will raise at high rpms but will not lower Please share any thoughts
Thanks
Rick
Ol Chief
09-20-2006 19:40:16
 Re: 830 CK 3 point problems one more time in reply to Rick Wages, 09-20-2006 18:26:33
I agree with Bill plus maybe take photos at stages of removals if your memory is not real good.
Bill young
09-20-2006 19:24:03
Yes maybe i can help.hope i can discribe so you can get a half way clear picture.go under the center floor board. there is a valve body there just for the 3pt hitch.take the plate off the right side of that valve body 4 small bolts.there is two spools in there pay real close attention how you take parts out.number of small parts there pull the spools clear out.clean and replace them.i don't think you will have any trouble with this.i have done it several times without removing the body from tractor.just keep in mind the small parts and you will do great. sounds worse than it is.good luck i know you can do it.Bill
c hess
09-20-2006 18:59:53
Dont know about 830 but on 930ck there is hole in floor board that you put screw driver in an turn one way or other to regulate speed of lowering 3 point. Screw isOn top of valve body under right side under seat.
