vac brake seal notification
case
09-20-2006 15:43:09
I am in the process of reworking the brakes on my 49 vac and in studying the archives for tips I ran across a posting that at one time case sent out a bulletin saying two seals needed to be used in place of the one original. Would like to get some clarification or if someone has that bulletin I would appreciate a copy sent via email. Thanks for the help! Case
Richard G.
09-21-2006 06:03:45
 @budweiser.com in reply to case, 09-20-2006 15:43:09
The new seals are much thinner than the old ones. When this is the case, I always out two seals to fill the space the old one filled. This way they can"t twist out of line and you have twice the sealing power.
Richard
MikefromIowa
09-22-2006 09:03:52
 Re: @budweiser.com in reply to Richard G., 09-21-2006 06:03:45
Yep, use 2 seals. I also used 2 seals for PTO shaft and axle shafts.
