Sleeves and pistons for a 49 SC Case
Keith Gibson
12-12-2000 15:55:25
Does anyone know if and where a sleeve and piston set might be found for a 49 SC Case?
Ed cielecki
12-21-2000 04:30:50
 Re: Re: Re: Sleeves and pistons for a 49 SC Case in reply to JohnH, 12-13-2000 03:46:24
I started rebuilding my SC a couple of months back and ran into the same problem of finding pistons and sleeves. The other two postings are correct- you need to get the sleeves from Case directly. The pistons are "backordered" which means that when they get enough orders they may make a run of them...good luck. You are better looking around for a new ring set and a couple of decent used pistons. There are used tractors out there in the yards with good parts. Try a dealer in PA - KINGS Tractors. 717 area code. I do not have the rest of the number handy right now. Ask for AAron. Good Luck
