VA Parts
Rob Pearce
11-28-2000 15:05:39
Hi: I still need a hydraulic pump, or the two internal springs, for my case VA. The pump I need is the one mounted under the belt pulley assembly. Can anyone help me?
Rob
12-06-2000 13:39:07
 Re: Re: VA Parts in reply to Butch Keiper, 12-02-2000 19:23:54
Hi Butch:
I sent you an e-mail regarding what I would like to get from you. If you had the straight piston (versus the mushroom piston) springs that would be my first choice. If you don't have those I would like to get a quote on the pump. Again the pump I need goes below the belt pulley. My tractor does not have the eagle hitch set up.
Thanks,
Rob
Marty
11-30-2000 09:30:32
 Re: Re: VA Parts in reply to Wynne, 11-28-2000 16:43:05
To Wynne, Does the tractor you are parting have the eagle hitch ? I could use the hydraulic pump
which mounts ahead of the distributor. Thanks
Wynne
11-30-2000 18:06:53
 Re: Re: Re: VA Parts in reply to Marty, 11-30-2000 09:30:32
Marty,
My tractor does not have an eagle hitch on it. Thanks.
