Tractor radio noise.
Larry
11-15-2000 17:52:43
Lets see if I can get this right so it makes sense. I have a Case 400 that someone had put a radio on. The problem is,that it worked just fine until I gave the tractor a tune up. Now I can hear the ingnition noise over the radio. Here is what I did for the tune up. Points,condenser,cap,rotor,plugs,and plug wires. At first I thought it could be the plugs,because I used non-resister type plugs,so I put the old ones back in. Still the same,so then I suspected the plug wires,because I put on the wire core type.I looked at the old wires,and they were the same kind I just put on. Now I was wondering what my next move should be? I might try putting the old wires back on tomorrow,but I can't see where that would help. Any ideas?
TMAC
11-15-2000 19:54:17
 Re: Tractor radio noise. in reply to Larry, 11-15-2000 17:52:43
I suspect your old wires were resistor type and not solid core like the new ones. Try them again and see. I can't think of any other noise suppressor that would be on it. Since you made the changes you would have seen them. I run my LA with solid core wires but my wife doesn't want me running it while she's trying to watch TV.
