Eagle Hitch question
Jim
11-13-2000 13:14:39
Does an eagle hitch hook on to category I implements? If I have implements for an 8N, will they fit on to an eagle hitch? Thanks for any help
george
11-16-2000 13:29:01
 Re: Eagle Hitch question in reply to Jim, 11-13-2000 13:14:39
Jim:
I have a '59 611B and use many 3-pt CAT 1 inplements. I have noticed that some need either spacers on the pins or snap pins through the holes to secure the implement from moving within the hitch (these are slightly narrower that the 26" spacing). I have had problems with a subsoiler, and wound up bending the pins since the hitch was at the end of each.
John in SD
11-13-2000 15:34:45
I think it depends on the implement. I have a 6 ft Dearborn blade with Cat 1 on my DC. Works great on it. Neat feature about using a blade on the Eagle hitch is that there is no side to side play. I can see where you would run into problems trying to mount something like a 3pt mower on the Eagle Hitch. I think the DC PTO shaft is way too high on the tractor in relation to the hitch. Never tried a 3 pt mower but I had to make a taller PTO shaft support bracket for my IH 1100 trail mower to hook up to the DC. Same problem with a 3 pt post hole digger. It won't work either.
