LA chains
Duane
11-07-2000 05:15:58
What is the best and simplest way to tighten the chains in the rear end of the LA?
Jim Phelps
11-07-2000 18:41:16
 Re: Re: LA chains in reply to Bob, 11-07-2000 10:58:47
I believe you would be better off to drain the tran. and jack up the tractor to adjust the chains as you have to lossen the axle housings. you also have to turn each wheel over at least one complete revolution to be sure there are no spots in the chain that are too tight. The chains must be adjusted that the tightest spot has a little play.
